Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Generator problem
buickanddeere
07-26-2013 06:13:43
JD. As everybody else has said. The bare exposed, uninsulated chassis ground is not supposed to carry neutral conductor current. Neutral current is supposed to be carried by the white insulated conductor. Electrical service ground rods are not supposed to carry neutral current either. That is why livestock receive shocks at water fountains.
JD Seller
07-26-2013 08:08:05
 Re: Generator problem in reply to buickanddeere, 07-26-2013 06:13:43
B&D I did not say that the bare frame ground should care the neutral but I want the generator FRAME grounded. I have seen generators mess up inside and electrify the frame. You walk up and touch it and you get shocked.
He needs a four pin/prong plug and a transfer system to be really safe.
I also think the frame should be grounded too. I do mean an earth ground too not hooked to the internal house ground.
buickanddeere
07-26-2013 08:25:07
 Re: Generator problem in reply to JD Seller, 07-26-2013 08:08:05
ok,just making certain. I had figured you were up to speed on the topic. Actually the house or utility service ground rod is a good place to ground the generator case. Of course now we get into portable generators, some with floating neutrals and some gen sets with bonded neutrals. My summer neighbour with a camper trailer used to have problems . He had a small gen set with a bonded neutral for light loads.And a large genset with a floating neutral for AC loads and cooking etc. GFI's would trip.
John T
07-26-2013 08:52:21
 Re: Generator problem in reply to buickanddeere, 07-26-2013 08:25:07
Be careful Glen, when you speak of floating or bonded Neutrals YOU WILL LOOSE THEM I TELL YOU LOL I doubt lay people will ever grasp that concept..........Just saying
John T
