TractorLinks.com
Tool Talk Discussion Forum
Re: drill press math
Indiana Ken
07-25-2013 07:59:52
The formula is: Output Rpm = Motor Rpm x (Driver/Driven) x (Driver/Driven) x (Driver/Driven).
Example 1) If you use a 1" pulley on the motor and a 12" pulley on the chuck we have; Output Rpm = 1725 x (1/12) = 144 Rpm at the chuck. As previously posted, 1" is a little small for a v-belt motor pulley - to prevent slippage you could go with a cog belt.
Example 2) Using a 3" pulley for the motor and the sprocket sizes you mentioned, we have; Output Rpm = 1725 x (3/12) x (22/45) = 211 Rpm for the shaft to which the 45 tooth sprocket is attached.
From your post I was not clear how the 30 tooth sprocket was to be used. If it is to form another gear reduction set then simply insert the (driver/driven) tooth ratio into the above formula.
dpendzic
07-25-2013 11:05:55
 Re: drill press math in reply to Indiana Ken, 07-25-2013 07:59:52
Yes-if the 45 tooth drives the 30 tooth then there would be a 50% increase in RPM at this point
