Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: electrical question
John T
07-25-2013 05:52:20
Thanks for the kind words and your question is a good one often asked.
Heres the deal as brief as I can make it (Engineer and Attorney mind you lol). If you supply a sub panel fed from your main panel, to that sub you carry sufficent Hot UnGrounDED Conductors (2, L1 & L2 for 120/240),,,,,,,,A Neutral GrounDED Conductor,,,,,,,,,An Equipment GroundING Conductor.
At the sub the Neutral Buss and Equipment Ground Buss ARE TO REMAIN SEPARATE AND ISOLATED. Yes that means any tie bar (N to G) is removed HOWEVER the panels metallic case frame, same as any other metallic enclosures, requires a bond to the equipmet ground which may be accomplished by a screw that goes from the ground buss into the frame BUT THATS NOT THE SAME A N TO G TIE BAR MIND YOU
Got it???????
John T
07-25-2013 07:51:30
 Re: electrical question in reply to John T, 07-25-2013 05:52:20
So I can ground the green wire to the panel box. That panel is just fastened to wood and the only connections to the first sub (which is another main panel)is the hot and neutral feeding this box.
It is hard to explain things, a picture is worth a thousand words.
John T
07-25-2013 08:47:00
 Re: electrical question in reply to JOB, 07-25-2013 07:51:30
Yep, the green wire to the panels case,,,,,,The Neutral NOT ATATCHED TO THE CASE,,,,,,Any outgong branch circuits Green to the case, Neutrals to the Neutral.
John T
07-25-2013 10:23:19
 Re: electrical question in reply to John T, 07-25-2013 08:47:00
thanks John T.
