Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: WD45 overheating issue
my55wd45
07-24-2013 09:11:37
Hi all,
I stopped by to do some further evaluation on the tractor. Near as I can tell, according to the serial #208662 or something like that, the tractor should be a wd45, or at least the rear half. the radiator shroud has a faded wd sticker with no 45. The research that I have done says if it is a wd there will be a bolt on plate on the right side of the engine block. If it is a wd45, there is no plate. This one has a bolt on plate so it should be a wd. Correct? The serial number I was referring to was located on the top of the trans housing. Is it possible that this tractor is a wd with a wd45 rear end?
Dusty MI
07-24-2013 17:47:19
 Re: WD45 overheating issue in reply to my55wd45, 07-24-2013 09:11:37
Go here for the location of the serial number location.
http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm
Dusty
