Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Running pancake air comp.off a 5500 watt genset
jeffcat
07-22-2013 19:13:01
HEY GUYS.... the shut off switch 'PRESSURE SWITCH" should have the little unloader built in. Everyone is correct with the "pissssh" went it shuts off. I am wondering how he hasn't burned the motor up yet if his unloader is not working. Switch busted internaly?
Now if you are a contractor you pick up an EMGLO or the new name is JENNY and with those compressors you can have it "on off" or it will idle with an uloader valve that lets the compressor go around without pumping any air. The pressure drop on/off is like only maybe 5 lbs.and then the pump starts pumpin again. I have one and it is so SWEET!! Like I said I think his pressure switch is broken.
Copyright © 1997-2015 Yesterday's Tractor Co.
