TractorLinks.com
Tool Talk Discussion Forum
Re: WD45 overheating issue
old
07-21-2013 20:56:45
Well lets start small and work up. If no water in the oil or oil in the coolant then. #1 radiator need to be washed out so air can flow threw it.
#2 clogged up cooling system that needs to be flushed. I use vinegar.
#3 bad thermostat
#4 bad water pump
#5fan belt bad or loose And I could add more but those are the most common
my55wd45
07-21-2013 22:12:01
 Re: WD45 overheating issue in reply to old, 07-21-2013 20:56:45
Thanks for the reply "old". According to what I seen when looking at the tractor, I didn't notice anything in the oil and no oil was evident in the radiator. There was no white smoke in the exhaust like when coolant enters the combustion chamber. The fan belt seemed ok. In your opinion, would this tractor be worth $1200.00? It has a loader and a dirt and snow bucket that comes with it. It has been converted over to 12 volts. The rubber is very good all around. I welcome your opinions.
old
07-22-2013 08:13:17
 Re: WD45 overheating issue in reply to my55wd45, 07-21-2013 22:12:01
Well with good tires that brings up the price a bit. Figure new tires for it would cost you $800 plus now days. That said I have seen them sell for as little as $750 at auction I know I payed that for the WD45 I have and I have also seen a WD sell at auction for $2500. Here in Missouri the WD and WD45 seem to sell well
JD Seller
07-21-2013 22:54:08
That is kind of full market value on them around here. I think with the overheating issue it is too high a price. A good running , no issue WD-45 will hardly break $1000 around here. North-East Iowa.
my55wd45
07-21-2013 23:35:11
 Re: WD45 overheating issue in reply to JD Seller, 07-21-2013 22:54:08
Thanks JD. That is good to know. That will help with the bartering process. What is a fair price to offer?
Glenn F.
07-22-2013 04:46:45
 Re: WD45 overheating issue in reply to my55wd45, 07-21-2013 23:35:11
A lot depends on how mechanical you are. If you are looking for trouble free ease and reliability then this 50+ year old tractor is not for you.
That said, if the rear tires are in like-new condition, the engine block is not cracked, and (assumed somewhat modern) loader is not damaged/extensively welded, you really can't go wrong at $1,200. But I'd still start negotiating at $900.....
Glenn F.
