old generator controlling rpm
i got this old genrator starter.....whats the thaught on using it on a go cart......would it hold up on continual use.....not sure if its 6 or 12 volt.....
how would i go about controlling speed of the generator ......
thinking of using a 10 or 12 tooth sprocket...it has a 72 tooth sprocket on a 12 inch tire.......
thanks for any help
this is a starter generator......like this one here http://www.ebay.com/itm/Simplicity-Allis-Chalmers-starter-generator-/130938721095?pt=LH_DefaultDomain_0&hash=item1e7c8e5347#ht_528wt_932
do you still think it would suck
Generator starters are only good for short term use. If you have what I think you do. Draw quite a bit of amps to get rolling.
