PEX manifold
The questions continue. We are near the plumbing rough in stage. We will be using PEX in a home run configuration. What I need is a PEX manifold with 10 hot water and 14 cold water. Any suggestion on sources and brands?
It's a Manobloc. Nice thing about it you can shut off each individual line if you need to work on a faucet, ect. will post a pic later.
We mounted this on the ceiling in the basement instead of the wall. Hope this helps..
This is what I used from Menard's. I have (2) 6-port manifolds for cold and (2) 4-port manifolds for hot. Used the crimp-ring style. Did it in 2006. Very happy with it.
Mike
