Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: 480V 3 phase to 240V single phase
Deere Mark
07-18-2013 19:33:10
I second the suggestion to wait for your electrician. Only a qualified electrician could determine what is right for your plant. Usually with 480 volt three phase, you would have 480 volts between the three hot wires and 277 volts from each hot wire to neutral. You could use a single phase transformer with 480 volt primary and 240 volt secondary. Or you could use a single phase transformer with a 277 volt primary and 240 volt secondary. The KVA of the machine to be powered would determine the KVA of the transformer.
Copyright © 1997-2015 Yesterday's Tractor Co.
