Ohiopioneer
New User
Hello, need some help here. A week ago I drove my tractor too close to the ponds edge and got it submerged up to the air intake. The air intake sucked in a little water which stalled the engine. Only about a quart of water got into the crankcase. But the 12 speed transmission filled with water and the mix of oil and water turned to foam. 20 gals of it! I got the tractor all drained and dried, runs great but I lost the low range gears. The two stage clutch seems to work fine. I tried to pull start it while I pulled it home. I knew that was a mistake. So did my pulling it damage the transmission or did running the transmission with water in it. If so where do I look for to be damaged. I have the rebuild manuals but there is no trouble shooting chart to guide me.
