TractorLinks.com
Tool Talk Discussion Forum
Re: sharp ax
Stan in Oly, WA
07-17-2013 08:58:38
Tim,
Thanks for your interesting and informative response. When you say "if you have a good axe and a poor axe and spend an hour using each of them", I guess that gets to the heart of the matter. I'm not sure I've ever spent a whole hour using an axe, and if I have, it's been more than 40 years ago. I have several axes which I'm beginning to realize fall into the category of tools which I like and respect, but actually have little or no use for. Others I own which also fall in that category include a peavey, a brush hook, several draw knives, hand planes, braces and bits, and probably a dozen or more others which I can't think of right now. All I can say is that I'll be pretty well set up for hand tools if we ever go back to pre-industrial conditions.
Thanks,
Stan
TimV
07-17-2013 11:41:48
 Re: sharp ax in reply to Stan in Oly, WA, 07-17-2013 08:58:38
Agreed and understood--that's why I mentioned it. I, on the other hand, tend to use hand tools, including most of the ones you mention, quite frequently, as in many cases I prefer them to the modern equivalent. It's often quicker to grab a hand tool for a short job than round up a power tool, find gas/oil/extension cords/etc., set everything up and then take it apart and put it away afterward. Examples include a hatchet with a homemade handle and sheath that stays behind the seat of the truck and gets used frequently to brush out the rural roads and trails I travel and a bit brace with a countersinking tip that stays permanently in it and hangs on my shop wall for quick one-or-two-hole jobs. To each their own, but I find considerable enjoyment in using and maintaining older tools, and in keeping the knowledge of their use and care alive.
Stan in Oly, WA
07-18-2013 11:31:09
 Re: sharp ax in reply to TimV, 07-17-2013 11:41:48
Tim,
I thought I was old school for still using power tools with an extension cord.
I still use non-power hand tools, too, just maybe not to the extent you do. I commonly use handsaws, coping saws, keyhole saws, miter saws, etc. rather than the equivalent power tool---particularly for a small job. I've probably used a small, sharp bow saw for hundreds of jobs where another person would probably use (misguidedly, in my estimation) a chain saw. It's easy to take up a tree or ladder with me, can almost always be used with one hand, starts every time, doesn't kick back, and it's wonderfully quiet. I still nail things together when that's faster than using a nailer, and sometimes when it isn't. However, I feel that the knowledge of how to use those kinds of tools is going to die with us.
Stan
Mike (WA)
07-17-2013 10:34:01
If you're trying to split wood, a sharp ax is the last thing you want- needs to be blunt enough not to stick in the wood. That's about all most folks use an ax for these days (even limbing is better done with a chain saw). Splitting maul is better suited to bigger and tougher splitting, but I'd still rather have a dull ax for easy-splitting wood- not so much weight to swing around.
Even better is my neighbor's wood splitter. . .
