TractorLinks.com
Tool Talk Discussion Forum
Re: Just another quick update...
RustyFarmall
07-12-2013 08:50:06
I just barely even know what you are talking about, and still, I am impressed!
Stick welding
07-14-2013 22:25:18
 Re: Just another quick update... in reply to RustyFarmall, 07-12-2013 08:50:06
Those are test coupons from a pipe weld. After welding, the pipe is cut in strips, ground flat with slightly rounded corners and then bent 180 deg's. You're generally allowed about 1/8" total allowable flaws adding all the bend tests together. If you grind it too much can fail before they are even bent. If you look close, you'll see that 2 of the bends are bent from the inside (root) of the pipe and the other 2 are from the outside(face) of the pipe. The pipe is all welded from the outside and you need 100% penetration, however if you have too much penetration, it will also fail before being bent. That's why some welders can make the big bucks.
