TractorLinks.com
Tool Talk Discussion Forum
Re: 20 amp single pole switch
buickanddeere
07-11-2013 20:15:10
If the switch does not have the "T" for tungsten lamps. It's not legal even if it is a 20 amp switch supplying a single 60W lamp.
Ultradog MN
07-12-2013 06:35:50
 Re: 20 amp single pole switch in reply to buickanddeere, 07-11-2013 20:15:10
Thanks B&D,
Shouldn't be a problem as I'll just run out and buy a $150 halogen light. It's just on my deer stand anyway so it doesn't have to be fancy.
Greg 2N (TX)
07-11-2013 22:53:52
If not a "T" then what, the contacts can't handle the arc when contact is made and broken?
So tungsten has lower resistance until it heats up in the bulb, then is that initial turn-on current the problem?
Is the issue arcing that can cause explosions?
Respectfully,
Greg
Bob
07-12-2013 00:19:55
 Re: 20 amp single pole switch in reply to Greg 2N (TX), 07-11-2013 22:53:52
To formulate a basic understanding why switches have a "tungsten" lamp rating, GOOGLE "incandescent lamp inrush current".
Greg 2N (TX)
07-12-2013 05:24:10
 Re: 20 amp single pole switch in reply to Bob, 07-12-2013 00:19:55
Thanks Bob,
The 60W incandescent bulb can have up 15 "times" more current at inrush over the steady state current.
The inrush would be 7.5A for a 60W and 15A for a 100W bulb.
Regards,
Greg
Greg 2N (TX)
07-12-2013 05:44:53
 Re: 20 amp single pole switch in reply to Greg 2N (TX), 07-12-2013 05:24:10
Inrush maximums
7.5A for 60W
12A for 100W
15A for 120W
Greg
Greg 2N (TX)
07-12-2013 05:08:07
Here Bob,
A more direct note on 60W incandescent bulbs that can have as much as a 15% higher inrush current (7.5A), still safe in my mind for a 15A switch, although the "T" type will have a longer service life.
http://www.powerbox.info/ssl/inRushCurrent.asp
Greg
