TractorLinks.com
Tool Talk Discussion Forum
Re: 20 amp single pole switch
dr sportster
07-11-2013 10:33:57
Article 999.99 -9 . Toggles on switches and all cover plates must be of the same variety. Exception 1 tan covers and ivory toggles may be mixed. Then from the Handbook[ which gives further info]. Installations of non-matching toggle switches and cover plates have been the cause of many explosions and vast fire damage to many facilities. All screws must also be correct paint shades Exception .1 Bathroom screws must be nylon or non-conductive and may not be required to color match. Automotive paints shall not be used to change colors by repaiinting. Exception 2 Stainless steel plates Exception 3 if the switch body is blue and going into a plastic box of matching blue color any color plate may be used.
Be careful .
Mike (WA)
07-11-2013 21:15:29
 Re: 20 amp single pole switch in reply to dr sportster, 07-11-2013 10:33:57
"Explosions and vast fire damage" caused by using the wrong color cover plate? You're kidding, right?
"Surely you can't be serious."
"I'm very serious. And don't call me Shirley."
Ultradog MN
07-11-2013 20:15:58
Thanks DS
I picked that color box and switch because they match my tractors.
farmerjohn
07-11-2013 18:51:43
Does it say anything about all the cover screw slots must run in the same direction? Just a pet peeve of mine. :)
dr sportster
07-12-2013 09:27:56
 Re: 20 amp single pole switch in reply to farmerjohn, 07-11-2013 18:51:43
Thats funny I used to make all the screws verticle. Once a co-worker installed a plate on a multi-gang switch set-up and didn't do that and the building manager called the shop and said the other guy left the screws all messed up. The contractor didn't know what he was talking about.
Matt Tieken
07-17-2013 05:47:51
 Re: 20 amp single pole switch in reply to dr sportster, 07-12-2013 09:27:56
I don't see why all electricians don't do that. It doesn't take any more work, and it looks a lot better when it is done.
