Cutting steel siding
Use a sharp utility knife and a straight edge. Score the sheet several times, bend back and forth at the score line. Works slick. :D
I use a metal cutting circular saw that has virtually no vent holes for metal filings to get in and damage the brushes.
I believe the duty cycle is such that you have to let them cool on longer run jobs.
Greg
As Scott said, scoring with a utility knife works well. I usually use a metal nibbler running along a clamped-on straight-edge of some kind, but that means you"d have to have a nibbler. Try the utility-knife trick first.
If it was only one sheet I would use a 4 1/2" grinder with a zip disc.
I use that thing a lot these days to cut most any metal under a 1/4". It cuts clean and fast.
Be careful about cutting with anything that makes hot sparks, they can land on a painted surface and melt into the paint.
Dusty
I've put saw blades on backwards on circular saws and even bought a carbide saw blade made to cut steel and both have shot chunks of steel into my skin. The easiest and safest way I've found is to use a metal cutting corborundom blade for the saw. It spits sparks and you need a full face shield and hearing protection but it doesn't spit shrapnel.
(quoted from post at 13:46:54 07/05/13) Install an old wood cutting blade backwards in a regular circular saw. Seems to work ok.
[color=red:8c81e05928]WEAR EAR PROTECTION IF YOU DO THIS![/color:8c81e05928] (don't ask me how I know)
buy a nibbler. the BEST money you will ever spend if you work with pole barn metal much at all. We did the backwards plywood blade thing for years....then got a nibbler. Maybe a $150.00? It is a electric Makita. GREAT tool.
