Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Nickel MIG Wire for Cast Iron?
S.D.L.
07-05-2013 21:10:35
Wanting to build up an area about 1"x1" on a cast iron exhaust manifold for machining.
shawnspeed3
07-06-2013 07:07:17
 Re: Nickel MIG Wire for Cast Iron? in reply to S.D.L., 07-05-2013 21:10:35
Machine the square/round out of plain steel & braze it in place...this will create the least amount of stress in the part...2nd would be to gas weld the material on (cast iron rod & flux) with proper pre-heat & post weld cool down(think low & slow)....Shawn
S.D.L.
07-06-2013 11:24:47
 Re: Nickel MIG Wire for Cast Iron? in reply to shawnspeed3, 07-06-2013 07:07:17
Thanks Shawn, as well as everyone else. I will probably go with your 2nd option. Thanks!
S.D.L.
07-06-2013 17:11:00
 Re: Nickel MIG Wire for Cast Iron? in reply to S.D.L., 07-06-2013 11:24:47
I meant to ask, but forgot. Where do you all get your cast iron rod and which flux do you use for best results? Thanks!
shawnspeed3
07-07-2013 07:44:44
 Re: Nickel MIG Wire for Cast Iron? in reply to S.D.L., 07-06-2013 17:11:00
I save old cast iron rings for small jobs, or order the rod thru the local welding supply.here is another source...http://www.tinmantech.com/html/cast_iron_welding_supplies.php
george md
07-06-2013 21:27:36
SDL,
I get the cast iron rod from Tucker Valve
Seat co in texas. The best flux is from Superior
flux in cleveland oh.
Break a piece out of an old bath tub to make
the repair piece , very good cast iron. Do heat
the whole manifold to at least 1000 deg before
you weld, and heat 1500 and hold for 15 minutes
and very slow cool from 1500 to 1200 ( 30
minutes) then slow cool on down . The rate from
1500 to 1200 will make the cast very machinable,
if it chills in that temp range ,it will be
very hard and even carbide tooling doesn't
like it . high speed tooling won't touch it.
Below is a before and during repair of a
wauk manifold. Also a link to more of that
repair.
george
jon f mn
07-07-2013 03:21:44
 Re: Nickel MIG Wire for Cast Iron? in reply to george md, 07-06-2013 21:27:36
WOW, that is amazing work!!! I've done a few manifolds as well, but nothing that bad. Very impressive.
george md
07-07-2013 10:51:01
 Re: Nickel MIG Wire for Cast Iron? in reply to jon f mn, 07-07-2013 03:21:44
Jon,
Next time you are in this end of the country stop in ,can show you many more disasters.
Many of the jobs come in with some flavor of arc weld and failed, have to remove all that garbage and do it with rod and flux.
http://imageevent.com/gmachine/manifoldandcastironrepair/twincitymanifoldrepair
The twin city was local when I fixed it ,was sold at auction , went Mn.
jon f mn
07-07-2013 12:28:11
 Re: Nickel MIG Wire for Cast Iron? in reply to george md, 07-07-2013 10:51:01
LOL, Everyone has disasters. I could show you a few of those as well. I would imagine MD is Maryland? Where?
george md
07-07-2013 14:36:54
 Re: Nickel MIG Wire for Cast Iron? in reply to jon f mn, 07-07-2013 12:28:11
Jon,
18 miles north of where you were in aberdeen
60 miles south of where you were in harrisburg.
george
mj
07-06-2013 10:50:56
What he said as the '2nd method' - peen the area around the welds after welding/brazing (stress relief) and then cover the part in a box of sand to cool out. For the 2nd method I'd use brass if the manifold doesn't get too hot or use a torch and cast rod & flux as others said.
This post was edited by mj at 10:58:54 07/06/13.
Earl-IL
07-05-2013 21:27:44
Torch and the square cast rod & flux. I have a spray torch I like, with cast powder. Both work good & machine with no hard spots.
jon f mn
07-05-2013 21:20:29
Are you trying to mount something?
This post was edited by jon f mn at 21:27:00 07/05/13.
Copyright © 1997-2015 Yesterday's Tractor Co.
