TractorLinks.com
Tool Talk Discussion Forum
Re: I think I need a new welder
Greg 2N (TX)
07-05-2013 17:54:09
The difference between pure copper and pure aluminum is significant when you are talking 225 Amps of current, enough to generate excessive heat.
Pure copper has about 38% less resistance than the same size aluminum.
My guess is that they are using an alloy mix that has resistance closer to copper.
The only reason to use higher resistance wire than pure copper ( other than cost) is to form a current limiting action at the cost of excessive heat.
Aluminum house wiring in the old days was downright dangerous especially with high current stuff.
BTW, I have a piece of flaked off wire insulation from my AC-225 and will check at what temperature it starts to melt. Let me just say this, i held a lighter to one of those flaked off pieces and guess what. It not only melted but caught fire too. Those engineers are not formulating the wiring varnish very well!
Regards,
Greg
Stan in Oly, WA
07-05-2013 19:37:58
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-05-2013 17:54:09
Well, two things (and then I'm not going to post on this thread any more---I feel like I've about run what I have to say into the ground). Pure copper may have 38% less resistance than the same size aluminum conductor, but aluminum has a moderate weight advantage and a significant cost advantage over copper so there's no reason to use the same size. Aluminum cables supplying electricity to a residence are much larger than copper cables which would carry the same load, and they're still just a fraction of the cost of copper.
The other thing is that aluminum house wiring wasn't dangerous because of heat generated by high resistance. It was dangerous because it expanded and contracted at a different rate than the dissimilar metal (i.e. non-aluminum) screws to which it was attached in outlets (and probably switches, too). This caused attachments to loosen which led to arcing which led to fires. This is still a problem in electrical service panels where the aluminum supply cables attach to the lugs. It's less serious than the old aluminum house wiring because most homeowners and amateur electricians are rightfully wary of working this far upstream, and real electricians know how to deal with it. But lots and lots of illegal and/or incompetent wiring of lighting and outlet circuits has always been done, and always will be. That's why aluminum house wiring stopped being legal many years ago.
I don't think you and I are disagreeing about anything. We're talking about different aspects of the same thing.
Stan
Greg 2N (TX)
07-05-2013 20:11:51
 Re: I think I need a new welder in reply to Stan in Oly, WA, 07-05-2013 19:37:58
OK Stan,
I really do appreciate your time.
I'm glad there are some good folks around to set me straight.
Thanks,
Greg
