Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: I think I need a new welder
Greg 2N (TX)
07-04-2013 21:09:40
I am a beginner stick welder with an AC-225, 275A diode bridge, and a choke coil out of a Weldanpower G8000.
My only fear with my 20% duty cycle limit is overheating the transformer's winding insulation.
My only hope is to attach a thermocouple to the transformer laminations so I can monitor the core temperature every so often between welding runs.
And stop when the temperature rises by about 40 deg C.
Greg
Stick welding
07-04-2013 21:42:52
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-04-2013 21:09:40
Just use it. I doubt you're going to pouring rod after rod of 5/32" or bigger rods. Do a weld, chip it off and do another weld. That will give a little time to cool off between rods.
Greg 2N (TX)
07-04-2013 21:52:54
 Re: I think I need a new welder in reply to Stick welding, 07-04-2013 21:42:52
Yea I used 5/32 rod after rod just last week and did stop to let it cool at times but I tell you what I could almost fry an egg on that ^* transformer. Reached underneath for grins just too see how hot and man I was worried.
Don't have the the dough for a nice power plant 100% duty rig so I'll be careful with what I've got for now.
Regards,
Greg
36 coupe
07-05-2013 02:44:39
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-04-2013 21:52:54
Its time to buy a Lincoln Idealarc 250.Weighs twice as much as your 225.Needs a 70 amp service.A new one costs 2 grand.Duty cycle is much better.
36 coupe
07-08-2013 16:40:02
 Re: I think I need a new welder in reply to 36 coupe, 07-05-2013 02:44:39
There a Lincoln Ideal arc on craigs list for 160 bucks asking price. AC/DC. If I were younger Id buy it.My DC converter cost 100 bucks to build.I had a lot of the parts on hand.You can put a small welder into failure mode if you push it.
Greg 2N (TX)
07-09-2013 21:47:48
 Re: I think I need a new welder in reply to 36 coupe, 07-08-2013 16:40:02
Thanks 36 coupe,
I was lucky to get some parts cheap locally.
$50 for Weldanpower inductor choke (never used)
$60 for four 275A stud diodes
Free aluminum heat sink plates for diodes
Etc. etc
Well I have to hold on to the money right now, times are getting tuff for somes of us...
For now I'll just keep the run time down and watch the temp.
I have a K type thermocouple 3" stainless probe that I'll thermally attach to the laminations and run the lead outside to read temps. I'll have to turn the welder off before connecting the probe since the mag field will cause erroneous measurements if not overload the meter input.
Take care,
Greg
