Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: I think I need a new welder
36 coupe
07-04-2013 01:07:23
Copper wire in a Lincoln 225 main windings is a fable.I bought my 225 in 1964 for 93.00.
Stan in Oly, WA
07-05-2013 10:27:18
 Re: I think I need a new welder in reply to 36 coupe, 07-04-2013 01:07:23
Hi 36 coupe,
AC or AC/DC?
In 1964 I had what was considered a decent job for a high school student---box boy in a supermarket making around $2 an hour. Today, the minimum wage in this state is more than 4 times that, but a Lincoln 225 AC is only about 3 times what you paid that year. So things are getting cheaper. Of course, gas now costs about 15 times as much as it did then, and houses cost about 25 times as much, so you've got to pick your bargains.
Stan
36 coupe
07-05-2013 23:07:17
 Re: I think I need a new welder in reply to Stan in Oly, WA, 07-05-2013 10:27:18
It was just AC, delivered to my door.I bought a 50 lb box of 1/8 rod for 9 bucks.In any case a 93.00 selling price was too low to use copper windings.There was a 180 amp welder made by Lincoln that drew just 37.5 amps at full output.It must have had power factor capacitors to keep input current that low.I have done minor repair work on small welders and never saw any copper wire in the main windings.
Greg 2N (TX)
07-04-2013 06:53:07
Oh my...
Sorry I was over optimistic.
I've never owned one until recently and a lot of folks keep saying the old units had copper and not copper-alloy. Some say that they are now all Aluminum which would really be high resistance.
So were the older units still only good for about 20% duty cycle at 225 Amps?
Greg
Stan in Oly, WA
07-05-2013 10:58:43
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-04-2013 06:53:07
Greg,
Why do you say that aluminum windings would have really high resistance? Aluminum has the 4th least resistance of any metal (silver, copper, gold, aluminum, in that order). It was used for house wiring in the mid to late 20th century (that use was ended for problems other than its efficiency), and it is currently much more common than copper for feeder lines in residential and light commercial installations (larger installations than that I don't know).
The Lincoln Electric representative/historian who told me that Lincoln 225 buzz boxes have never been manufactured with copper windings on the transformer, said that some Idealarcs were copper and some were aluminum but that I would never be able to notice the difference. My guess is that it's a status kind of thing, as it is with most consumer products: If someone knows there's a difference, then they swear that they can detect the difference, but blind comparisons usually demonstrate that they can't. Well conducted tests have shown that people who won't drink any other vodka but Grey Goose (or any other high priced brand) are consistently unable to pick it out of a group of six brands---including really cheap ones---in blind taste testing.
Stan
Stick welding
07-05-2013 20:22:09
 Re: I think I need a new welder in reply to Stan in Oly, WA, 07-05-2013 10:58:43
Copper is better but for most projects you'd never notice any difference. The best example of why copper is better deals with Lincoln SA 200 engine drives. Pipeliners noticed that on the machines made from about 73 with aluminum shunt coils, that the machines would heat up and not keep consistent amperage settings. They'd start off in the morning and after a couple hours have to turn their heat up. Then after they had lunch, the machines would be too hot and they'd have to turn them down again. For THIS application, the aluminum was a real PIA! So much so that Lincoln went back to all copper in the Classic and later pipeliner series machines. Price out a 200D pipeliner and you'll see they cost more than a larger non true DC generator machine.
Greg 2N (TX)
07-05-2013 17:54:09
The difference between pure copper and pure aluminum is significant when you are talking 225 Amps of current, enough to generate excessive heat.
Pure copper has about 38% less resistance than the same size aluminum.
My guess is that they are using an alloy mix that has resistance closer to copper.
The only reason to use higher resistance wire than pure copper ( other than cost) is to form a current limiting action at the cost of excessive heat.
Aluminum house wiring in the old days was downright dangerous especially with high current stuff.
BTW, I have a piece of flaked off wire insulation from my AC-225 and will check at what temperature it starts to melt. Let me just say this, i held a lighter to one of those flaked off pieces and guess what. It not only melted but caught fire too. Those engineers are not formulating the wiring varnish very well!
Regards,
Greg
Stan in Oly, WA
07-05-2013 19:37:58
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-05-2013 17:54:09
Well, two things (and then I'm not going to post on this thread any more---I feel like I've about run what I have to say into the ground). Pure copper may have 38% less resistance than the same size aluminum conductor, but aluminum has a moderate weight advantage and a significant cost advantage over copper so there's no reason to use the same size. Aluminum cables supplying electricity to a residence are much larger than copper cables which would carry the same load, and they're still just a fraction of the cost of copper.
The other thing is that aluminum house wiring wasn't dangerous because of heat generated by high resistance. It was dangerous because it expanded and contracted at a different rate than the dissimilar metal (i.e. non-aluminum) screws to which it was attached in outlets (and probably switches, too). This caused attachments to loosen which led to arcing which led to fires. This is still a problem in electrical service panels where the aluminum supply cables attach to the lugs. It's less serious than the old aluminum house wiring because most homeowners and amateur electricians are rightfully wary of working this far upstream, and real electricians know how to deal with it. But lots and lots of illegal and/or incompetent wiring of lighting and outlet circuits has always been done, and always will be. That's why aluminum house wiring stopped being legal many years ago.
I don't think you and I are disagreeing about anything. We're talking about different aspects of the same thing.
Stan
Greg 2N (TX)
07-05-2013 20:11:51
 Re: I think I need a new welder in reply to Stan in Oly, WA, 07-05-2013 19:37:58
OK Stan,
I really do appreciate your time.
I'm glad there are some good folks around to set me straight.
Thanks,
Greg
Stick welding
07-04-2013 20:43:07
It's funny how people rant about the AC 225 being so bullet proof yet you never see any in welding shops. They're OK for a hobby or small farm welder but are still a low end machine. They were always 20% duty cycle.
Greg 2N (TX)
07-04-2013 21:09:40
 Re: I think I need a new welder in reply to Stick welding, 07-04-2013 20:43:07
I am a beginner stick welder with an AC-225, 275A diode bridge, and a choke coil out of a Weldanpower G8000.
My only fear with my 20% duty cycle limit is overheating the transformer's winding insulation.
My only hope is to attach a thermocouple to the transformer laminations so I can monitor the core temperature every so often between welding runs.
And stop when the temperature rises by about 40 deg C.
Greg
Stick welding
07-04-2013 21:42:52
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-04-2013 21:09:40
Just use it. I doubt you're going to pouring rod after rod of 5/32" or bigger rods. Do a weld, chip it off and do another weld. That will give a little time to cool off between rods.
Greg 2N (TX)
07-04-2013 21:52:54
 Re: I think I need a new welder in reply to Stick welding, 07-04-2013 21:42:52
Yea I used 5/32 rod after rod just last week and did stop to let it cool at times but I tell you what I could almost fry an egg on that ^* transformer. Reached underneath for grins just too see how hot and man I was worried.
Don't have the the dough for a nice power plant 100% duty rig so I'll be careful with what I've got for now.
Regards,
Greg
36 coupe
07-05-2013 02:44:39
 Re: I think I need a new welder in reply to Greg 2N (TX), 07-04-2013 21:52:54
Its time to buy a Lincoln Idealarc 250.Weighs twice as much as your 225.Needs a 70 amp service.A new one costs 2 grand.Duty cycle is much better.
36 coupe
07-08-2013 16:40:02
 Re: I think I need a new welder in reply to 36 coupe, 07-05-2013 02:44:39
There a Lincoln Ideal arc on craigs list for 160 bucks asking price. AC/DC. If I were younger Id buy it.My DC converter cost 100 bucks to build.I had a lot of the parts on hand.You can put a small welder into failure mode if you push it.
Greg 2N (TX)
07-09-2013 21:47:48
 Re: I think I need a new welder in reply to 36 coupe, 07-08-2013 16:40:02
Thanks 36 coupe,
I was lucky to get some parts cheap locally.
$50 for Weldanpower inductor choke (never used)
$60 for four 275A stud diodes
Free aluminum heat sink plates for diodes
Etc. etc
Well I have to hold on to the money right now, times are getting tuff for somes of us...
For now I'll just keep the run time down and watch the temp.
I have a K type thermocouple 3" stainless probe that I'll thermally attach to the laminations and run the lead outside to read temps. I'll have to turn the welder off before connecting the probe since the mag field will cause erroneous measurements if not overload the meter input.
Take care,
Greg
36 coupe
07-04-2013 10:22:09
Lots of liars on forums.
Copyright © 1997-2015 Yesterday's Tractor Co.
