TractorLinks.com
Tool Talk Discussion Forum
Re: Splicing 4/0 feeder
Sparktrician
07-02-2013 14:08:37
The thing about this is, you are just making a band-aid! It may last forever.....but.....the fact of the matter is that one day it will likely burn up. Underground splices with AL are hard to get watertight.....even with heat shrink and everything else available.
My advice, make CERTAIN you know exactly where the splice was made, so if it burns up, you know where to fix it. I understand about budgets.....but do what you can to make for a easier fix when it does go south.
Use de-ox or no-lox gel/compound when making your splices. Use it liberally, once your splice is made, cover the entire connector in it before you put the first heat shrink on. I would recommend no less than 3 heat shrinks, getting progressively longer by 2' increments. that way each heat shrink is 1' longer on each end than the last.
remember.....more is better here.
Good luck
jammison
07-02-2013 15:39:53
 Re: Splicing 4/0 feeder in reply to Sparktrician, 07-02-2013 14:08:37
Quoting Removed, click Modern View to seeI feel that there are people here who have made bad splices before or else there wouldn't be so many nay-sayers, BUT....the local power company makes then in this hood all the time. Everyone here irrigates (too much), so it is easy to spot them when they go bad. Just watch for steam rising from the earth! They just do them over. Usually last 10-12 years. Yes, aluminum.
Sparktrician
07-03-2013 12:46:42
 Re: Splicing 4/0 feeder in reply to jammison, 07-02-2013 15:39:53
Exactly my point, 10 to 12 years.
