TractorLinks.com
Tool Talk Discussion Forum
Re: For Puddles or any of the welders here.
caterpillar guy
07-01-2013 19:49:46
Stan, The rod is 6011 not 6010. No warpage just seems like the metal is to hot. If I turn the heat up it wants to burn away. Also the rail and cross members are light weight material. You have to look under junior beams for the cross members the side rails are probably about 1/8 inch. So can't get to high on the amperage settings. Did do some the other day at 90 amps seemed to burn away faster. I will get some pictures and check the welder settings for sure tomorrow when I'm out in the shed.
Stan in Oly, WA
07-01-2013 21:33:19
 Re: For Puddles or any of the welders here. in reply to caterpillar guy, 07-01-2013 19:49:46
Caterpillar guy,
Yes, 6011. I don't know which is worse any more, my memory or my attention span. Anyway, 6011 is very similar to 6010 except that it has some additives in the flux to make it run on AC, which 6010 virtually won't.
It sounds to me like you did it right and it worked. I didn't understand that the materials you were welding were so lightweight. A job like that is usually quite a challenge. Thin material which burns through easily, deep penetration rod, vertical up where the heat (and the chance of burning through the material) increases as you go. I'd say you could just as easily be bragging about a good outcome as wondering whether you did anything wrong.
Stan
