Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Autotransformer
buickanddeere
06-20-2013 05:53:06
Cheaper to build per KVA. No electrical isolation between primary and secondary windings.
Brad Buchanan
06-20-2013 10:06:19
 Re: Autotransformer in reply to buickanddeere, 06-20-2013 05:53:06
Hi all,
I can understand how placing several taps on the secondary windings of a transformer to get different voltages.
However, if there is no electrical isolation between the primary and secondary windings would this not just be a direct connection between the primary and secondary coils?
Would the current not seek the most direct path to ground ie. the load and not energize the primary to create the pulsating magnetic field to energize the secondary windings?
Brad
JMOR
06-20-2013 10:48:56
 Re: Autotransformer in reply to Brad Buchanan, 06-20-2013 10:06:19
Bead, see if this helps with visualization:
http://www.transtutors.com/Uploadfile/CMS_Images/21190_Auto-Transformer.JPG
May be many more taps such as C', C'', C''', etc.
Brad Buchanan
06-20-2013 13:09:33
 Re: Autotransformer in reply to JMOR, 06-20-2013 10:48:56
Ok, I understand that. It looks like a variable resistor. Any tap will always be less than V1.
Would there be another core and coil to drive V1?
Brad
JMOR
06-20-2013 16:53:35
 Re: Autotransformer in reply to Brad Buchanan, 06-20-2013 13:09:33
Quoting Removed, click Modern View to seeYes,, if you count the one on the power pole owned by power company.
