TractorLinks.com
Tool Talk Discussion Forum
Re: Follow-up Billy Bob Electrical Question
dr sportster
06-19-2013 10:12:39
The breakers were 44 dollars each GFI used to cost about 10-11 dollars so when a contractor wired a house it was cheaper to run several GFI requirements off the breaker. After the cost of GFIs came down [wire went way up] it was mostly done by a GFi at some locations then standard receptacles GFI protected on the load side of the GFIs. I see they are now made in China. At the house protects the whole line going out. But with all the nicks in the wire from the sleeving each piece of conduit the GFI is unlikely to hold as all pipes get filled with water.You run pipe then you pull wire. The only exception is in a factory that must stay running while controls are changed out . Then you have to prep up all you can ahead of time and may have rolled up wire at ends of uncompleted pipe runs.
Which is not a code violation.
