TractorLinks.com
Tool Talk Discussion Forum
Re: Any more bearing stores around?
oliver power
06-19-2013 00:55:30
Yes NCWayne, You are correct. Motion did not fold. They closed the store near me. Which I discovered after I posted. And I Thank You for the link to Bearing Distributors. We'll give them a try.
carogator
06-19-2013 17:43:43
 Re: Any more bearing stores around? in reply to oliver power, 06-19-2013 00:55:30
Just be aware, Bearing Dist. has a no refund policy and a minimum purchase. A $2.50 Item is still $10.00. NOTICE! At our local store, NO RETURN even if, they determine the part you need, and it is wrong.
NCWayne
06-20-2013 07:34:16
 Re: Any more bearing stores around? in reply to carogator, 06-19-2013 17:43:43
I've been doing business with Brng Dist for nearly 18 years, and Dad has been using them far longer than that. In all that time I have never heard of a 'no return' policy on anything, as long as it was still in the origional packaging and hadn't been used. Even then if you attempted to put on a belt, etc and found it didn't fit there was no issue returning it as long as it hadn't been in actual operation.
Areo
06-19-2013 14:35:41
I've had good luck dealing with ABC. (Accurate Bearing Company). They are in Chicago area and Texas. You can get cheap bearings or better quality depending on what you need. Also some other related items.
Areo
