In an earlier post, it was recommended the circuit be protected with GFCI.
Does it matter WHERE the GFCI is located?
My reason for asking: My house had a GF Breaker to protect bathroom & outside receptacles. ....Nuisance tripping would require a trip down to the basement breaker panel to reset the GFCI.
I replaced the GFCI breaker with a standard breaker, but all recepts on that circuit have been changed to (or fed by) GFCI"s.
I"m thinking a fault in Ultradog"s deer stand will require a walk back to the house to reset a tripped GF breaker (if installed there), whereas GFCI"s inside the deer stand will allow resets in the stand.
Is my thinking correct? ...Or, am I creating a different problem?
