Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: AC units tripping surge protectors
George Marsh
06-17-2013 12:03:29
JohnT,
I never wire a ref to a GFCI. I use GFCI in kitchen, garage, basement, outside, any place they will get along with motors.
What amazes me is that I have 2 wells wired to a GFCI. One well the pump is above ground and the other the pump is in the well. Both pumps get along with the GFCI.
You may be wondering why I have them wired up to a GFCI? I'm using the GFCI as a disconnect. I have a water alarm that shorts ground to common if it detects water on basement floor. Shorting ground to common on the GFCI will trip it, disconnecting power to the pump. It really works, prevented my basement from a flood when the water softner decided to spring a leak.
Back to the AC problem. #1 Why not remove the power cord, install an old power without protection, connect it to a grounded outlet and see what happens? #2 Or plug in the old style 3 prong cord from A/C in to an extension cord with a GFCI?
I would do #1 first while measuring the current on both the power and ground wire. I like to live on the edge. Love to see sparks fly, don't you? Stimulates the heart. If A/c works, then move to #2.
George
John T
06-17-2013 12:35:27
 Re: AC units tripping surge protectors in reply to George Marsh, 06-17-2013 12:03:29
Nor did I wire or design any fridges to GFCI circuits and it was all legal and NEC proper due to the "Exception" I cited.
There are all sorts of ways (NEC and home made, perhaps safe and proper perhaps not) to shut off a branch circuit for safety reasons, in my practice days I specified shunt trip breakers controlled by a remote sensor circuit.
I'm like you, Id consider in my own home rewiring the AC BUT AS AN ATTORNEY AND ENGINEER I'm naturally reluctant to give such advice to others, Do as I say NOT as I do lol lol
Nooooooooooooo I dont like to see sparks FLYyyyyyyyyyyyy Im a chicken when it comes to electricity
Take care, fun chattin
John T
Dusty MI
06-17-2013 16:44:43
 Re: AC units tripping surge protectors in reply to John T, 06-17-2013 12:35:27
I helped build a restaurant once. It had fire suppressant system. If that system went off all the exhaust fans shut down. Those fans were single and 3 phase. They all had an extra breaker tied/riveted to there breaker, that's the only time I've seen a 4 pole breaker. That extra breaker was only 5 or 10 amp. The fire suppressant system shorted that extra breaker to ground, and because of the tie handle it shut down the fans.
Sorry about getting side tracked.
Dusty
Copyright © 1997-2015 Yesterday's Tractor Co.
