TractorLinks.com
Tool Talk Discussion Forum
Re: AC units tripping surge protectors
John T
06-16-2013 08:54:58
Are what you call "surge protectors" the over current and overheat thermal protectors (what I suspect, maybe a red push to reset button???) or some sort of voltage spike (maybe from lightning) supressors or some sort of GFCI protectors???????
If its really the overcurrent thermal protectors (I suspect) and trip that fast, Id guess the compressors are seized up. Perhaps the fans may be stuck which manually turning may help but Id guees it would take a bit of time before they (low current draw) kicked any protectors
Darn if I know not being there
John T
M-MAN
06-16-2013 09:42:16
 Re: AC units tripping surge protectors in reply to John T, 06-16-2013 08:54:58
A couple more possibilities to add to John T's probability. Could be moisture in the unit & there is alway's the possibility of a tad too much oil getting inside the compressor when moving around a window shaker. Let it sit a while and try it again. Bumping the compressor would help but that's kind of hard to do without taking it apart. One of mine did that last year when I first plugged it up but worked perfect the next day.
