Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Slowing down a drill press
Dusty MI
06-14-2013 04:00:06
Question about Variable Frequency Drive.
The belt changing drill presses work very well because when you want a slow speed because your using a large bit, the torque is greatly increased. When using a high speed for a small bit you loose the large amount of torque, but don't care because it's not needed.
So if you had a drill press with a 1/2 hp. motor which worked fine with the belt changing set-up, and changed it to a 1/2 hp. motor with VFD, would it work as well ?
I get tired of changing belts.
Dusty
Copyright © 1997-2015 Yesterday's Tractor Co.
