TractorLinks.com
Tool Talk Discussion Forum
Re: Slowing down a drill press
buickanddeere
06-13-2013 08:51:17
VFD. Variable speed and torque limiting to reduce bit or tap breakage. Reversing capability too. Low purchase price too.
Bus Driver
06-15-2013 18:18:24
 Re: Slowing down a drill press in reply to buickanddeere, 06-13-2013 08:51:17
VFD is not suitable for single phase motors. Those motors have very little torque if slowed much below full RPM. And most VFDs are designed for 3- phase motors only
Dusty MI
06-14-2013 04:00:06
Question about Variable Frequency Drive.
The belt changing drill presses work very well because when you want a slow speed because your using a large bit, the torque is greatly increased. When using a high speed for a small bit you loose the large amount of torque, but don't care because it's not needed.
So if you had a drill press with a 1/2 hp. motor which worked fine with the belt changing set-up, and changed it to a 1/2 hp. motor with VFD, would it work as well ?
I get tired of changing belts.
Dusty
