TractorLinks.com
Tool Talk Discussion Forum
Re: Slowing down a drill press
mj
06-12-2013 14:43:02
What gtractorfan said and go look at some in the store with triple pulleys - the only hard part is getting an eccentric (for belt tension) to mount the bearing & shaft for the 3rd pulley - years ago I used an aluminum round turned to fit the drill press column I.D., bored an off-center hole to fit a water-pump shaft and bearing off of some long-forgotten car (used a set-screw to keep the bearing's external housing from rotating) and then bored a hardware store step pulley to match the w'pump shaft's O.D. I sold it to a friend over 30 years ago and he still uses it. Now, if my old Atlas quit and couldn't be fixed (which I doubt) I'd just buy another press - getting lazy I reckon. JET has a good reputation; have you looked at their catalog? Might be you could upgrade from their parts book. :idea:
