TractorLinks.com
Tool Talk Discussion Forum
Re: Torch regulator question
Stick welding
06-11-2013 19:22:42
I wasn't beating up on anybody. I don't want to see someone get blown up. There's no way the acetylene gauge should go up when draining the oxygen with the cylinder closed. There'd have to be some kind of obstruction. He didn't say if he closed the acetylene valve after draining the hose. I would think most people close the valve after draining the hose though. Flashback arrestors do have check valves but most new torches come with one or the other. I've seen gauges on new torches that crept up but they were the cheap knock off sets. Still he should go back to where he bought it and find out what's wrong.
JOB
06-12-2013 04:40:24
 Re: Torch regulator question in reply to Stick welding, 06-11-2013 19:22:42
The only way that gauge on the acetylene side can go up with the acetylene bottle shut off is with a bad torch handle valve, which isn't likely to be that bad, or else with the valve open.
I would expect the valve to be shut off also but that is the only way oxygen can get in that line and make the pressure build with the acetylene bottle turned off.
