Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Best Way to Drill Large Hole
06-11-2013 14:11:30
Pilot hole helps a lot when you have light equipment or hand held. Where most screw up is making the pilot hole too large. All you have to do to make a sharp 3/4 bit feed easily is to drill a pilot the same size as the width of the point, likely around 3/16" to 1/4" Certainly no larger than 5/16" If your 3/4 bit doesnt feed easily with a 1/4" pilot you need to sharpen the bit, not make the pilot hole larger.
Eric in IL
06-11-2013 16:25:18
 Re: Best Way to Drill Large Hole in reply to Butch(OH), 06-11-2013 14:11:30
Scrolling through the comments, I found one I really like. I bet Butch(OH) has drilled a hole or two.
06-12-2013 06:58:24
 Re: Best Way to Drill Large Hole in reply to Eric in IL, 06-11-2013 16:25:18
Thanks, Yes I have turned a few tons of steel into turnings over the years. I know what works for me but sometimes it doesn"t work out my way when others are doing the work so I make suggestions based upon my guessing the skills and equipment of those who ask. Actually I don"t pilot drill anything below 1". I thin the webs of my large bits so they start and feed easily but you cant tell somebody who doesn"t know how to thin the webs that they should do that can you? A pilot bit is the next best choice (which is not a step drill in my nomenclature) In the shop we now run spades that pilot in a 1" Hole for anything 1-3" and anything over 3" pilots on a 2" hole. Really nice system but beyond the average guys pocketbook or needs and certainly not for hand held equipment.
jon f mn
06-11-2013 17:16:09
I've drilled a lot of hole too and I agree. To large of pilot hole and you can damage the bit. I always use 1/4" for holes up to 1".
36 coupe
06-11-2013 15:16:11
A 3/4 inch drill has a thick web that makes it hard to start cutting.A smaller drill can be used as a starter but then only to make a shallow starter hole.Anyone who does step drilling better own a lot of drills.I have some old drill motors that will hurt you if the drill catches.
