TractorLinks.com
Tool Talk Discussion Forum
Re: What is the correct way to adjust your gas while MIG welding
jon f mn
06-11-2013 06:01:14
There are many reasons that could have happened. A bad stretch of wire is quite common. Wire varies a lot and I've had to toss more than one roll because it didn't work, some for feed problems because they had bad shape and wouldn't feed even. Some for content problems that caused what you have. If it only lasted for a bit it could be gas contamination in the gun from something you did while changing the roll. I've also seen bad spots or contamination in the iron give problems. Without seeing it while you are welding, anything I say is just a guess tho. That is the problem with giving advice here, diagnosing a welding problem, especially with mig, is as much about sight and sound as the technical settings and we don't have that here.
