drill chuck
Check somewhere like Travers Tool, or WT Tool, both have web sites. That said, there are too many different attachment sizes/methods, both threaded and tapered, to say for sure whether anyone would have one or not.
(quoted from post at 20:52:31 06/10/13) Were can I get a chuck for my sears drill press it"s 113.213151 sears no longer has them . THANKS RON
Try ereplacementparts.com. Do a part number search if you are lucky enough to have it, if not use the model number and give it a try.
That chuck will be the same one used on many different applications, so if you know the diameter of the arbor and the thread per inch you should be able to find a generic one easily enough.
May not have it listed by model number for equipment thats too old, but hey, it's worth a shot. Good luck sir....
The replacement part number for the drill chuck is 817340. Ryobi/Ridgid uses the same drill chuck on their drill presses. http://www.mowtownusa.com/Ryobi-Ridgid-Part-817340-IC-CHUCK_p_154496.html
There should be a Part number stamped or
engraved right onto the chuck, like a JACOBS
CHUCK number.
Victor Machinery Exchange: www.victornet.com
A machine shop supply firm, has many chucks listed
You might also try MSC(Manhatten Tool Supply). This where I get most of my shop equipment as well as KITTS INDUSTRIAL TOOLS and KBC TOOLS
Have you determined how the chuck fastens to the drill press... screws on, inserts into Morse Taper hole in spindle, or goes OVER a Jacobs Taper or other taper ON the spindle?
Look closely at the chuck for markings such as "MT2", meaning #2 Morse Taper or "JT3", meaning #3 Jacobs Taper, for example.
Once you have determined this, chucks are pretty generic.
I just dealt with this and bought keyless chucks for two drill presses from www.shars.com.
REASONABLE prices and FAST shipping.
