TractorLinks.com
Tool Talk Discussion Forum
Re: Electric chain saw
Dave Sherburne NY
06-10-2013 14:24:35
If you have a battery powered reciprocal saw, put a long blade on it and let her try that. I have a remington electric chainsaw, and the chain seems to be different than a gas saw (less teeth). Used it Sat to clean up a couple of limbs that blew down worked fine but I wouldn't want to cut a years firewood with that chain.
RayP(MI)
06-10-2013 17:26:20
 Re: Electric chain saw in reply to Dave Sherburne NY, 06-10-2013 14:24:35
I have one too - am told the fewer teeth are because the electric motor doesn't have enough power to run a conventional chain. My take is that it is rough running, tends to chatter a lot. OK for a little limbing but I sure wouldn't want to use one for serious wood cutting.
George Marsh
06-10-2013 19:03:44
 Re: Electric chain saw in reply to RayP(MI), 06-10-2013 17:26:20
My electric is not a skip tooth, it's a regular oregon chain and bar, 62 tooth 18 inch bar. It may run at a slightly slower speed. Produces long wood chips, not saw dust. Stays sharper longer, as long as I don't put in the dirt. Chain stays cool and doesn't need adjusted. My 4 hp has all the power you want. I was helping a friend, who only had a 16 inch gasser. I could make more cuts than he could. He had to stop, gas up, tighten chain, and hit chain with file. The only time I stopped was to put oil in. It was funny to watch him start his saw. His wife stood on the saw while he pulled the rope. By the time the saw started, he was tired. I cut circles around him.
George
Dusty MI
06-10-2013 16:34:56
If you think that you might ever need to trim a tree, get an electric pole saw. You can take the pole off and use just the saw. I have a 16" Remington and wish I had a pole for it.
I have a 4000 watt belt driven generator, that I run with my 17 hp garden tractor. I use that for running the electric chain saw.
Dusty
