TractorLinks.com
Tool Talk Discussion Forum
Re: Shop Electrical Issue
dr sportster
06-07-2013 20:12:10
The welder fan is 110 v . It will run if you lost one phase the lighting problem sounds like a neutral . Without coming to your place with a wiggy hard to troubleshoot by internet. I agree with the call an electrician answers.If you hsve a wiggy start by checking output of breakers at the panel[you did] then neutrals. Sounds like you welder receptacle is part of a multi-wire branch circuit hence the neutral and lost phase symptoms but hard to tell.
buickanddeere
06-08-2013 06:47:00
 Re: Shop Electrical Issue in reply to dr sportster, 06-07-2013 20:12:10
Fan should be 240V.
Problem sounds like loss of one live line.
Stan in Oly, WA
06-08-2013 14:50:20
 Re: Shop Electrical Issue in reply to buickanddeere, 06-08-2013 06:47:00
But one of the things he noted was that the fan was still running. The loss of one live line and a 240 volt fan still running don't go together.
Stan
36 coupe
06-09-2013 04:57:49
 Re: Shop Electrical Issue in reply to Stan in Oly, WA, 06-08-2013 14:50:20
Stan get a pencil and draw a diagram of a 240 3 wire circuit.Open a fuse on 1 side.That side is dead until a water heater element turns on.Now the element feeds the dead side.Lights will come on dim and the fan motor will run wether its 240 or 120.I do think my Lincoln 225 welder has a 240 fan motor.I have run across the lost leg problem many times doing appliance repair.Happens a lot on underground service with aluminum wire.Ive found out side service lines open on one side.Happened in my barn shop.Fluorescent light came on very dim.Barn line has 40 amp fuses.Pull them and find one open.No problem , just an old tired fuse.
buickanddeere
06-08-2013 14:59:02
Fan will run on much less than 240V. It will spin just fine on approx 120V throught the neutral backfeed from the "dim light" side of the panel.
Stan in Oly, WA
06-08-2013 20:37:06
 Re: Shop Electrical Issue in reply to buickanddeere, 06-08-2013 14:59:02
One of these days, b&d, I'm going to be right and you're going to be wrong. Maybe next time.
Stan
dr sportster
06-08-2013 11:36:20
On my Miller the ON/Off switch is a two pole GE 50 amp breaker at the machine. I lost one leg and the fan was still running.
dr sportster
06-09-2013 09:51:30
 Re: Shop Electrical Issue in reply to dr sportster, 06-08-2013 11:36:20
A google search reveal Miller to have 230 /110 and 24 volt fans.
