TractorLinks.com
Tool Talk Discussion Forum
Re: Cement mixer gurus (and geometry guys)
Brad Buchanan
06-07-2013 16:09:45
Hey Jon.
Like the belt idea. Do you mean a standard vee belt or a wide belt?
Brad
jon f mn
06-08-2013 18:38:41
 Re: Cement mixer gurus (and geometry guys) in reply to Brad Buchanan, 06-07-2013 16:09:45
V belt will run on a flat pulley you just have to make sure the alignment is good. Depending on the gear reduction you may need a larger pulley on the motor. You will also need to make it so the belt can loosen for starting the motor or it may be difficult to get running. I had one on a sprayer pump and couldn't figure out why it wouldn't start till I loosened the belt then it started right up. They don't have enought hp to start under load.
Dusty MI
06-08-2013 05:23:48
I'm not Jon, but I would think a V-belt would work on the flat pulley on the mixer and a V-pulley on the engine. Better check the speed, with that speed reducer on the engine you might be a little slow.
Dusty
