TractorLinks.com
Tool Talk Discussion Forum
Re: 48v delco alternator?
mmidlammmidlammmidlam
06-07-2013 10:36:58
You can connect a 36 volt zener in series with the sense terminal of the alternator.This is not the best way but it can be used to check the alternator's ability at 48 volts..
George Marsh
06-07-2013 13:03:26
 Re: 48v delco alternator? in reply to mmidlammmidlammmidlam, 06-07-2013 10:36:58
I know how zeners work, but not completely following your logic of using a 36v zener. How is that going to be better than using a voltage divider? I'm leaning toward adding a variable resistor or pot to fine tune with.
I'm not 100% certain this pipe dream, which isn't mine, will work without frying the exciter/armature/rotor/voltage reg, or the entire alternator.
Also been thinking of applying full 12v to alternator and controlling it with the RPM's of engine.
JMOR
06-07-2013 20:10:11
 Re: 48v delco alternator? in reply to George Marsh, 06-07-2013 13:03:26
Quoting Removed, click Modern View to seeThe problem with simply sticking a "36v zener" in series with the sense lead is that it will be 36v at a specific zener current & I will guarantee you that such zener current is not the less than 1 milliamp sense line current. So, to use such a zener, you now need additional resistors to establish the proper zener current & to what advantage?
