Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Cement mixer gurus (and geometry guys)
Stan in Oly, WA
06-05-2013 18:16:23
Does quarter bag refer to the amount of cement you would use per load? I often use a 1:2:3 mix for general purpose concrete. That would produce 6/4 of a foot or 1.5 cu ft. of concrete. (Slightly less, actually, because you have to divide the volume of the separate dry ingredients by 1.15 to get the true volume of the concrete that they will produce.) A 5 cu. ft. mixer would make a bigger load than that.
Stan
dpendzic
06-06-2013 13:59:29
 Re: Cement mixer gurus (and geometry guys) in reply to Stan in Oly, WA, 06-05-2013 18:16:23
Stan--the 1/4 bag does refer to the cement concrete of the mix.and yes the yield on a concrete mix is always less than the total of the ingredients. The actual volume that it will mix well is dependent on the rotation speed,height of paddles and amount of residual hardened concrete in the drum.
we used to regularly inspect transit mix trucks and down rate their capacity as things wore.
