TractorLinks.com
Tool Talk Discussion Forum
Re: 48v delco alternator?
JMOR
06-04-2013 12:02:04
Quoting Removed, click Modern View to seeNo need to burn that much power with 10 & 30 Ohms, as 1,000 and 3, 000 Ohms will be fine. And that takes into account the ~1ma Sense (#2) drain.
The two spade terminals are #1 excite and #2 Sense. Right & left depends on observer's and alternators positions.
If you do as I suggested in post responding to sotxbill, then there will be no connection to spade #1. That will be covered by the removal of diode trio and the addition of an input to the point of the trios previous output.
Sounds like the plan is wind power. If it is, I see a problem in that if batteries are low, calling for charge AND there is insufficient wind, then the bottom battery is still being drained by the VR's demand for field current & at 3 amps field, it will discharge in less than a day. Assuming 66 A-H battery.
[/URL]
[/URL]
George Marsh
06-04-2013 13:49:01
 Re: 48v delco alternator? in reply to JMOR, 06-04-2013 12:02:04
JMOR,
THANK YOU. Actually the plan is not wind power. A friend, who I will not mention, he posts on here too, called me to do this. I had reservations as to if it will even work. He wants to use an engine/delco/4 12 batteries/48 volt dc motor to make a hybrid truck.
He was sure it would work. I saw this guy put a 5 hp briggs on top of an outboard gear drive. The outboard engine went bad. Not really sure if his air cooled outboard worked, but he has to get a red-neck award for trying the unusal.
Thanks Jessie for the diagram.
Let you know if he gets all the parts together and if it works. Looks easy to me with your diagram.
George
