TractorLinks.com
Tool Talk Discussion Forum
Re: 48v delco alternator?
Bob
06-03-2013 20:55:28
Oh, for gosh sakes, if you set up a conventional vehicle alternator up with a permag armature (rotor) the regulator in a conventional sense becomes a moot point!
(Cuz" the regulator normally controls current INTO the rotating field... permag field = NO wound rotating field = nothing for the conventional regulator to control.)
John T
06-04-2013 06:13:38
 Re: 48v delco alternator? in reply to Bob, 06-03-2013 20:55:28
Yep my Mechanical Engineer Sparky friend, thats why in those small PM DC Motors if you reverse the polarity they (unlike a typical tractor electromagnetic field starter motor) spin the opposite direction. The PM has a fixed North/South magnetic polarity and a fixed field strength so you cant alter any current flow like on an electromagnetic field generator to increase the output. The faster the rotor spins the greater the output induced into the stator, so regulation has to be accomplished quite differently.
Very fun sparky chat yall
John T
George Marsh
06-04-2013 05:26:02
BOB,
You are right. From what I've read, the wind generator's output if a function of it's RPM's. However, they are calling them 48 volt alternators. I'm going to guess the magnets are an energy saving device, so when there is no wind ther is no current drain.
Come to think of it, my old 1966 triumph 650 motor had a magnet connected to the crankshaft and the stationary coils around the magnet is where the induced voltage was made. So spinning a magnet really is a new thing. Back then, after the AC went throught the diodes, triumph used a zener diode as the voltage regulator, sending the excessive voltage to ground. Wind generators may be dumping their excessive voltage.
Everyone seems to be getting side tracked with terms and definations.
A friend wants a 48 v delco alternator to charge 4 12v batteries in series.
I need information on how to trick, modify, the voltage regulator to make 48v. So it seems everyone thinks it's possible, no one can tell me how to make it happen.
George
buickanddeere
06-05-2013 07:45:07
 Re: 48v delco alternator? in reply to George Marsh, 06-04-2013 05:26:02
48V alternators are an off the shelf item in the Delco catalog.
JMOR
06-04-2013 06:13:24
Quoting Removed, click Modern View to seeDid you say which Delco alternator?
