Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: 48v delco alternator?
George Marsh
06-03-2013 14:23:40
The current won't be any larger than the alternator's max rating. The resistance of the stator is the same, therefore the I squared R won't be a problem.
My concern is can the armature handle it? If you have an alternator say rated at 100 amps, should you push it to 100% or use some current less than 100%?
Last, where can you get a 48 volt regulator? The alternator will be connected to 4 12v batteries in series.
Bob M
06-03-2013 18:58:39
 Re: 48v delco alternator? in reply to George Marsh, 06-03-2013 14:23:40
George - You are indeed correct about I squared R heating of the stator not being an issue!
My concern rather is the rotating field winding. Depending on the alternator electrical characteristics, the field could draw as much a 4x design current for the alternator to deliver 48 volts. And this would mean 16 TIMES the heat developed in the winding. Whether or not it would be a problem is uncertain.
As for where to find a 48 volt regulator, suggest paying a visit to your neighborhood electronics nut. If he's any good it should be a relatively simple matter for him to cob up a 48 volt PWM field control regulator.
