TractorLinks.com
Tool Talk Discussion Forum
Re: Century Model 87151 Battery Charger
George Marsh
06-02-2013 20:02:02
It's still possible a 600w dimmer switch will work in place of the brain box, with the exception it won't shut off automatically. Think about this. If the input voltage is 120v and 5 amps = 600 watts. The output of a charger is 12v, in theory, the output amps should be 50 amps. That's just theory. Reality, a transformer isn't 100%, so there will be less than 50 amps out.
SOOO, I think a dimmer will work. What is there to loose? The charger is junk. A dimmer is a few bucks. I say by-pass the brain box with a dimmer and then tell me it doesn't work.
George
IH2444
06-03-2013 18:15:23
 Re: Century Model 87151 Battery Charger in reply to George Marsh, 06-02-2013 20:02:02
The dimmer will not work.
The "brain box" is on the output side of the transformer not the input side.
36 coupe
06-03-2013 18:04:38
The dimmer puts out a chopped voltage that will eat a transformer.A look at the output voltage on a scope will prove it.Dimmers are designed to work into resistive loads not transformers.
