TractorLinks.com
Tool Talk Discussion Forum
Re: Century Model 87151 Battery Charger
Bob
06-02-2013 17:03:08
I believe that one uses a SCR to regulate the charging rate to the various settings. If so, it needs that and it"s associated control circuit to function or things are gonna get ugly.
George Marsh
06-02-2013 17:52:42
 Re: Century Model 87151 Battery Charger in reply to Bob, 06-02-2013 17:03:08
If he can't get a brain box, then buys a new charger or perhaps uses a dimmer switch to control the output of charger. Apparently, the full out circuit must by-pass the brain box.
A while back, I showed how I controlled the output of a 12v charger with a dimmer. That way a person could charge a 6 or 8v battery with a 12v charger. I don't have a 6 or 8v battery, but the volt meter showed I could control the output voltage from zero to over 12v. It worked, but hummed a lot.
IH2444
06-02-2013 18:11:29
 Re: Century Model 87151 Battery Charger in reply to George Marsh, 06-02-2013 17:52:42
the dimmer switch thing only works on fairly low current (maybe 20 amp max) straight transformer types of chargers without electronic controls.
George Marsh
06-02-2013 20:02:02
 Re: Century Model 87151 Battery Charger in reply to IH2444, 06-02-2013 18:11:29
It's still possible a 600w dimmer switch will work in place of the brain box, with the exception it won't shut off automatically. Think about this. If the input voltage is 120v and 5 amps = 600 watts. The output of a charger is 12v, in theory, the output amps should be 50 amps. That's just theory. Reality, a transformer isn't 100%, so there will be less than 50 amps out.
SOOO, I think a dimmer will work. What is there to loose? The charger is junk. A dimmer is a few bucks. I say by-pass the brain box with a dimmer and then tell me it doesn't work.
George
IH2444
06-03-2013 18:15:23
 Re: Century Model 87151 Battery Charger in reply to George Marsh, 06-02-2013 20:02:02
The dimmer will not work.
The "brain box" is on the output side of the transformer not the input side.
36 coupe
06-03-2013 18:04:38
The dimmer puts out a chopped voltage that will eat a transformer.A look at the output voltage on a scope will prove it.Dimmers are designed to work into resistive loads not transformers.
