TractorLinks.com
Tool Talk Discussion Forum
Re: Air operated vacum pump ?
MarkB_MI
06-02-2013 13:38:49
JD, help me to understand how flushing with alcohol is going to remove moisture. After all, you can only distill isopropyl alcohol or ethanol to around 90-96 percent pure. Flushing with alcohol is going to ADD water to the system, not remove it.
Backing up a bit, how does water get into the system in the first place? You opened the system, and humid air entered it. OK, so you displace the air with your flush, which evaporates, leaving you with a system full of vapor that's 4 to 10 percent water. How do you get THAT out? My guess is you blow it out with compressed air, which leaves you right where you started: an A/C system full of wet air. (Now if you purge it with dry nitrogen, then that's another story. But the flush would still have not aided the process.)
Fact is, if you're not drying the system by pulling a solid vacuum (1000 microns or less), you're betting that the dryer will do it for you. Which you can probably get away with, IF you replace the dryer.
