TractorLinks.com
Tool Talk Discussion Forum
Re: welding with a pacemaker
rabbit
05-30-2013 18:28:42
Probably not a problem, But I'd be careful not to put myself between hot tip and ground, anyway. But best if you check with your physician. Son has a similar pacemaker, primarily set to defib... Doc told him he should avoid heavy duty chain sawing.
jwilmot
05-30-2013 18:55:13
 Re: welding with a pacemaker in reply to rabbit, 05-30-2013 18:28:42
The doctor says the worst that could happen is I get shocked really don't want that, but at 40yrs old I really am not ready to give up welding either .
CHARLES CRAIG
05-30-2013 21:14:48
 Re: welding with a pacemaker in reply to jwilmot, 05-30-2013 18:55:13
I had a pacemaker installed in march 2010. on my first doc visit he called {medtronics} and they said to stay as far away from the transformer as possible. my mig has a12 ft cable and couldn't tell the diff. CC
36 coupe
05-31-2013 07:12:16
 Re: welding with a pacemaker in reply to CHARLES CRAIG, 05-30-2013 21:14:48
I think the danger comes from hand to hand shocks that pass thru your chest.This type of shock can mess up heart timing and kill the pacemaker.Hand to hand shocks can make your chest and ache for hours.Most welders run 80 volts open circuit.Keep your gloves dry.
Stick welding
05-31-2013 22:26:29
 Re: welding with a pacemaker in reply to 36 coupe, 05-31-2013 07:12:16
MIG welding would be down around 20 volts in most cases but amps is the push of current.
36 coupe
06-01-2013 02:33:38
 Re: welding with a pacemaker in reply to Stick welding, 05-31-2013 22:26:29
Mig runs lower open circuit but you wont be touching the electrode like you do in stick welding.Kneeling on the ground and loading a new electrode with a bare hand will usually get you a shock.When the arc is broken there must be a high inductive voltage present.I think that electric shocks are bad news for pace makers.
Stick welding
06-01-2013 09:51:58
 Re: welding with a pacemaker in reply to 36 coupe, 06-01-2013 02:33:38
Never got a shock putting an electrode in but in school we had to hold the electrode in the stinger with one hand and ground with the other. That gives a good shock. It was done to show that a welder won't electrocute you. The teacher stopped doing it because he got a higher than normal shock once.
