To lube up the advance in a distributor I need to go
down the tube below the rotor and take out a outside
snap ring that has two pegs sticking up. Is there a
special tool for this. If so what is it called. Or
is there another method to remove that snap ring?
I am working on a mechanical advance distributor,
but would assume even a vacuum advance distributor
works the same way.
works the same way.
