Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: tire patch cement
old
05-25-2013 08:23:58
What I do is carefully use a grinder wheel on a 4 inch grinder to clean the tube and ruff it up. Then apply the glue and let it film over then lay the patch on. The glue has to sit a few minutes before you put the patch on it the patch will not stick
missouri massey man
05-26-2013 04:31:55
 Re: tire patch cement in reply to old, 05-25-2013 08:23:58
That's exactly what I use to buff them up. Also you can carefully remove the reinforced area around a detatched (ripped off) stem with the same process and glue a replacement stemmed repair patch over the existing hole. The trick is patience. If the rest of the tube is in good shape it is worth the effort considering the cost of tubes nowadays. IMHO anway.
Like old said above, the trick is letting the glue almost dry completely before applying the patch as it is a "contact adhesive". Then use the appropriate roller to roll from center out all the way around it forcing air out and forcing good contact between the surfaces. And don't touch the patch surface with your fingers as the covering is removed as contaminents will be added to the chemical bond effecting the outcome. Good luck on your next tube-patch adventure !!!
