TractorLinks.com
Tool Talk Discussion Forum
Re: Old Lathe and Drillpress
D beatty
05-25-2013 07:57:18
We had drillpress like that in our shop many years ago. The top of the drill shank was tappered and the end of it looked like a big flat screw driver. We had a piece of wood and tapped the end of the drill to set it into the tapped chuck. When done there was a tappered piece of flat steel (we called it a key) that there was a slot just over the top of the drill and you sliped the key in it and gave it rap and the drill dropped out of sleeve.
JOB
05-25-2013 08:40:57
 Re: Old Lathe and Drillpress in reply to D beatty, 05-25-2013 07:57:18
The tapered shank sounds like the Morse taper we have today. I haven't a clue what kind of chuck is on that drill press. Or if it is even called a chuck. Looks like every drill big or small would have to have the same size shank with a flat spot, or different Morse taper sizes, if they had Morse taper back in 1855.
D beatty
05-25-2013 16:44:56
 Re: Old Lathe and Drillpress in reply to JOB, 05-25-2013 08:40:57
They made an adapter that small drills would fit in . The small drills looked like the big drills and you used the adapter to make them work.We used ours mainly for drilling large holes. I think I may have a couple of these drills yet but don't have the drill press anymore.
D beatty
05-25-2013 08:03:26
The lathe that you have pictured does not have a chuck on it but has a faceplate and that is threaded to the head of lathe.
JOB
05-25-2013 08:31:02
 Re: Old Lathe and Drillpress in reply to D beatty, 05-25-2013 08:03:26
Did they have chucks back in 1865? Or was everything done off a face plate? I would think it would be kind of hard to fasten a piece of round to a face plate.
D beatty
05-25-2013 16:34:56
 Re: Old Lathe and Drillpress in reply to JOB, 05-25-2013 08:31:02
If that faceplate is threaded to head you should be able to take it off and find a chuck that fits those threads.
