TractorLinks.com
Tool Talk Discussion Forum
Re: tire patch cement
Richard from SE AZ
05-24-2013 22:14:21
I don't have ANY luck getting patches to stick to ANY tube. I wipe,clean with the tube cleaner used for that purpose,buff, glue, press with a weight or a vice, and they still will not stick for long or completely. I have been suspecting that the problem is the material in the tube. What am I doing wrong?
old
05-25-2013 08:23:58
 Re: tire patch cement in reply to Richard from SE AZ, 05-24-2013 22:14:21
What I do is carefully use a grinder wheel on a 4 inch grinder to clean the tube and ruff it up. Then apply the glue and let it film over then lay the patch on. The glue has to sit a few minutes before you put the patch on it the patch will not stick
missouri massey man
05-26-2013 04:31:55
 Re: tire patch cement in reply to old, 05-25-2013 08:23:58
That's exactly what I use to buff them up. Also you can carefully remove the reinforced area around a detatched (ripped off) stem with the same process and glue a replacement stemmed repair patch over the existing hole. The trick is patience. If the rest of the tube is in good shape it is worth the effort considering the cost of tubes nowadays. IMHO anway.
Like old said above, the trick is letting the glue almost dry completely before applying the patch as it is a "contact adhesive". Then use the appropriate roller to roll from center out all the way around it forcing air out and forcing good contact between the surfaces. And don't touch the patch surface with your fingers as the covering is removed as contaminents will be added to the chemical bond effecting the outcome. Good luck on your next tube-patch adventure !!!
hermit
05-25-2013 05:26:29
Me too Richard. I gave up. I wish you could still get hot patches.
mmidlam
05-25-2013 05:25:54
Different brands of patches and cement may not be compatible. I have learned the Master brand of patches and Victor cement are not compatible. Gemplers claimed the activator can be in the cement or on the patch for different brands.
Also the non-flammable cement takes longer to dry and get ready for a patch then the flammable cement,especially on a cold day.
